Problem with licence
Hi,
I installed to test the pabx in my notebook without problem.
I activate the licence that 3cx send me by mail.
But when I install the software over the definitive server, and I try to reactivate the licence in it I have this problem:
license.unexperrLicence Key Activation Failed Licence: 62 System: 0
I try to download a new file of the soft, but the licence code don't change, and my problem is on.
Thank you for help me to solve this problem.
Br.
Luis
Hi, this is the spanish forum, please post your question again in the English forum...
Estoy de acuerdo que se lleve esto al for de ingles, pero en caso de que a alguien le haya pasado lo mismo, aqui pongo la solucion que esta en el blog de 3CX
As part of our routine Security Audit checks, we have updated the client and server components of the 3CX PhoneSystem license activation procedure.
This means that activating your 3CX PhoneSystem requires the new version of the license activation module. This has been integrated inside the latest build (V 7.1.6589) which can be downloaded here: http: //www.3cx.com/downloads/3CXPhoneSystem71.exe
Please note that activation with earlier versions is no longer possible. Systems that need to be upgraded will show this message “License: 62″ when attempting to activate.
Already-running 3CX PhoneSystem installations will continue to run. However, reactivation for upgrades will require you to install the latest build.
Version 6.1 users who do not wish to upgrade to a more recent version, will have to patch the installation to the new version of the license installation module. To install the patch, this ZIP file (http: //www.3cx.com/downloads/v6/php_cmstatus.zip) must be expanded, and the file contained within with filename “php_CMStatus.dll” must be copied over the older version inside the path “C:Program Files3CX PhoneSystemBinPhpextensions”. After a restart of the machine, activation will be possible.
We apologize for any inconvenience this may cause.
Kevin Attard Compagno
Technical Support Manager
3CX - https://www.3cx.com
